How to reduce regeneration time for large pattern in Creo Parametric 11.0.4.0
A 3D model of a wire mesh net (1539.5 x 177.5 mm, wire diameter 0.5 mm). The pattern is created using 60 extrudes × 512 extrudes (total 30,720)
a. First pattern (512 instances, 177.5 mm each) I used "Identical"
b. Second pattern (60 instances, 1539.5 mm each) I used "General".
Whenever I change pattern options—switching between "Variable", "General", and "Identical"—the regeneration time is about 3 minutes. Is there any way to reduce the regeneration time from minutes to just a few seconds?
Note: I can't select both patterns as "Identical", because this prevents me from creating cuts/holes in the mesh model later due to self-intersecting surfaces. hence, I had to choose "General". But now regen time is too long.
