8-Gravel
November 23, 2023
IFX Fasteners uses checked in Windchill version
  • November 23, 2023
  • 2360 views
I made modifications to my fasteners, but when I assemble a fastener size that is checked into windchill it uses that version instead of new modified version. Is there anyway of preventing this?
I need some more information to answer this question.
  • Do you use the IFX family-table mechanism or do you have single fastener models?
  • Where are your modified fasteners are saved to?
    • Only to a local workspace
    • Only to a local drive
  • Can IFX access your modified fasteners?
    • Try to open the fastener with the model name with 'Creo - File Open' dialog
    • are the modified files loaded?
Maybe some screenshots and a little bit more details would be helpful.
gpedros8-GravelAuthor
8-Gravel
November 25, 2023
Hi Oliver,
  • I have single fastener models.
  • Models are saved local on the C: Drive to a folder I've created. They are not in the default Creo created IFX folder.
  • IFX seems to be able to access files because most fasteners work without issues except for the few sizes that are checked into Windchill.
  • I'm not sure what you mean by, are the modified models loaded?
So, here's an example of an old model that has been uploaded into Windchill.
  • The old models don't have threads the new models have the thread. Also, new models have new assembly constraints as you can see by the error message below. When I call this fastener up in Creo, it doesn't have the thread and in my workspace it shows that it is checked into Windchill.
This fastener should be a new object, but you can see it is not.
Old Fastener
New Fastener
If your new fastener is already in session, IFX should use the new one.
Otherwise I think the windchill fastener is prefered.
Why do you not upload your new fastener to Windchill?
