IFX counterbore pin holes - hole chart column for through hole diameter?
When creating a counterbore style pin hole with IFX, the software defaults the 'thru' diameter (labelled 'counterbore diameter' in the UI) to 1/2 of the nominal pin diameter. Our manufacturing standard requires a different diameter - is there a hole chart column that can be used to drive this dimension to a specific value so that the user doesn't have to manually change it every time?
We have tested with the known hole chart columns and none seem to work.
We are currently running Creo Parametric 10.0.5.0.
