If I create reps I can't change the colors.
How do you create those representations? If I create reps I can't change the colors. Only if I make appearances. But appearances cannot be set on the drawing... So If I set different appearance's on the combined state in the model it works just fine, but on the drawing it is not! How should I do it?
