Import loads in Creo Simulate 3.0
Hello.
I am facing a desperate situation right now.
We received from our customer a 3D model and an excel file containing a point cloud from their CFD analysis. The excel file is structured. There are the x-y-z-coordinates of each point and every point have also an information about the force that is applied in the particular point (also x-y-z-triplet).
With this information our aim is to make a FE-Analysis.
I managed to write a macro that exports the coordinates into an .pts file that Creo Parametric can handle. In the modeling environment I can see the points in 3D space.
But how can I import these information into Creo Simulate? I could import the point cloud and apply the forces manually to every point. But we have ~5000 points, that would be wasting of time.
My first idea was to use the excel macro to generate a file that Creo uses to read all the information about where the points are located and which load is applied. As far as i know Creo Simulate stores the "load information" in an .xml file inside the Analysis output folder. But in that file is no information about coordinates.
Is Creo Simulate even capable of "importing loads"? For me it seems to be a basic functionality that should be supported.
Thank you very much for any help you can give.
