Importing Mass properties
Marcusanthony
Is there any possible way to importing Material properties like density, Mass, etc. to creo from external file like Notepad or Excel?
Yes. The Creo .mtl material files are just text files. If you copy paste the values into a .mtl file or write a bit of VBA that writes to a .mtl file you can then import it into Creo as a material file.
