Insert Mode With Pattered Features in the Footer
  • March 24, 2010
  • 0 replies
  • 418 views
WF3, M170 & M200 & WF4, M100
I have a skeleton model developed in WF3.  I have a series of publish geometry features and I've placed all of them in the footer.  One is a publish of a pattern leader.  I have reference patterned the pub geom and ref patterned the copy geom and other features in downstream models.  So my ref pattern is in the footer.
If I try to drag my insert here bar up above the original patterned feature in my skeleton, it 'sticks' at that point, refusing to suppress the pattern.  It does, however, suppress all the features ahead of the patterned feature that are not parents of the patterned feature.  I can manually suppress the original pattern but cannot drag the insert line ahead of it.  Activating insert mode through the menus (edit -> feature operations -> insert mode -> activate) does the same thing.
Drag the ref pattern out of the footer, all is right with the world.
This was originally built in WF3 M170.  I upgraded to M200 and tried WF4 M100 with the same results.
Any solutions?
Doug Schaefer
