I have an issue that just recently started where when I have an open model I can not drag the green insert here bar, even when I have the item checked out. This is happening in prt as well as asm model trees.
I use Dell monitors for working and the "Dell Display Manager" was causing the issue. The app has been uninstalled and everything is working properly now.
please record mp4 video showing your activity and upload it.
please try steps mentioned in https://www.ptc.com/en/support/article/cs372602
Please next time give information about Creo version you use.
Martin,
Thanks for the response. I'm on Creo 6.0.6.0 I will include this in the future. The above works, but does not fix the underlying issue. Thanks for the help.
Nick
