Is it possible to rotate an surface edge around an axle? If not - is there any workarounds?
Is it possible to rotate an surface edge (3D) around an axle?
Is i possible to rotate anything else but a sketch?
There's no direct way to do so, but you can create the geometry with a variable section sweep. I covered this at MCAD Central a while back, check out this thread. Sample Creo 2 part in this post, full explanation starting in this one.
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
