Is possible in Creo Parametric (7.0 or 9.0) to create a clone part of one existing part?
ptc-290440
2-Explorer
By a clone part I mean a fully dependant copy of a part that can be used in separate assemblies but if the original part is modified, the clone part can be updated automatically, And if it is possible, can be assigned a different material to the clone?
tbraxton
(To:ptc-290440)
You can find the command here:
Watch this video from @DaveMartin for a guide to implement this method.
https://www.youtube.com/watch?v=mFjBrLiCE3w&t=5s
Make sure that your source and target models have the same absolute accuracy set. This is critical in top-down design data sharing features to avoid regeneration issues.
Involute Development, LLC
Consulting Engineers
6 REPLIES 6
tbraxton
(To:ptc-290440)
Yes, this is possible. You can use the master merge method to create the clone which will be a derivative part controlled by the master and fully dependent.
Thanks for your answer.
I have never use Master merge method.
Where can I find this option in creo?
tbraxton
(To:ptc-290440)
Hi @ptc-290440,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
PTC Community Moderator
PTC
Done.
Thanks for the support
BenLoosli
(To:ptc-290440)
Look at inheritance features for a dependent model copy. I think that will work, we don't use them.
Look at a family table where you have a single model with some features changed, like material. We use family tables for hardware items, nuts and bolts, etc. but you should be able to change the material of each instance.
