Isometric View with Perspective in Drawing
  • December 14, 2010
  • 12024 views
Hi, is it possible to get an isometric, shaded view with perspective added in a drawing? I can't seem to figure it out if it it's possible.
Hi
I think if you can make an isometric view in part or asm mode, you can create a new view in "orient" tab of view manager.
I should begin in part or asm mode an create that isometric view by turning the part or asm so you see it in isometric view.
Hope this helps you out.
Season's greetings
Chris
LeeCasey1-VisitorAuthor
I can confirm this does not work. The perspective is not added to the drawing view.
Anyone else with any suggestions?
another year, another year this does not work in Creo.
