Leave component unplaced option in Assembly
  • July 12, 2024
  • 3055 views
I am using creo 8.0.
Working in assembly , when I create new component I don't  see option of 'Leave the component un placed' which is usually on highlighted section. How can I turn it on ?
Below is image I found on website
Best answer by Lewis_Maina_M
I opened advanced CREO License and I can see the box.
kdirth
To leave it unplaced, simply select OK then press MMB.  Same number of clicks, less mouse movement.  Check box is not an option in 7.0 either.
Hello @kdirth  , attached screenshot has ASM0001 and ASM20002
ASM0001---I used your suggestion
ASM0002--- when you tick the box
Am looking for ASM0002 option. See icons are different.
