Leave component unplaced option in Assembly
  • July 12, 2024
  • 3055 views
I am using creo 8.0.
Working in assembly , when I create new component I don't  see option of 'Leave the component un placed' which is usually on highlighted section. How can I turn it on ?
Below is image I found on website
Best answer by Lewis_Maina_M
I opened advanced CREO License and I can see the box.
kdirth
To leave it unplaced, simply select OK then press MMB.  Same number of clicks, less mouse movement.  Check box is not an option in 7.0 either.
tbraxton
Creo 7.0.10.0 I see the check box for this option.
Lewis_Maina_M13-AquamarineAuthorAnswer
