Lenteur affichage
  • February 10, 2026
  • 2 replies
  • 212 views
I am using Creo Parametric Release 9.0 and Datecode9.0.11.0
Bonjour,
j'ai une pièce en tôlerie avec des formes en répétition (nombreuse). Sa mise en plan est très longue à s'afficher et son exportation en STEP par exemple est très longue aussi. Pouvez-vous m'aider à comprendre le problème ?
Peut-être faut-il ajouter une option au config.pro ?
Merci par avance pour votre analyse.
tbraxton
English translation.
I have a sheet metal part with (numerous) repetitive shapes. Its drawing takes a very long time to display and its export to STEP for example is also very long. Can you help me understand the problem?
Maybe we need to add an option to the config.pro?
Thank you in advance for your analysis.
tbraxton
There is not enough information to reply with an answer that is meaningful/relevant. If possible, upload the part or an example of one with this issue along with the drawing. If you are not able to upload the files, then at least show some screenshots of the models/drawings and the model tree with enough detail for a review of the model structure to be made.
If you have a pattern in the model with many instances, this can require long regeneration times and also affect the speed of rendering. If you do have patterns, try optimizing them by using geometry patterns or the pattern regeneration options. Use the identical option if available.
About Pattern Regeneration Options
Bonjour,
Vous trouverez ci-joint les fichiers PRT, DRW, mon "config.pro" et mon "iso.dtl" afin que vous puissiez faire les testqs.
Merci par avance pour votre retour
Cordialement,
Bernard PROTHIN
  Tél. : 33 (0)6.73.28.26.92
  Fax : 33 (0)9.72.13.30.88
  Email : bprothin@becala.fr
  Web : www.becala.fr
tbraxton
The code in Creo used for regeneration of models does not support multi-threading. When you have a multi-core CPU it is not going to show the CPU being used at a high level as the regeneration is only done by a single core. Patterns are known to require a lot of CPU cycles to regenerate. Assuming that rendering is handled by a PTC supported GPU then the geometry render would be handled by the graphics card and you can mitigate rendering time with display settings.
If you need to model the part with a large number of forms, then I would find a way to deal with the creation and regeneration of that geometry in a model external to the sheet metal part. You can then reference this geometry in the sheet-metal part using Top-down design tools, so the form geometry is not regenerated while you are working on the design in sheet-metal mode. You can further optimize workflow by putting the forming geometry at the end or as close to the end of the model tree as possible so that you can keep it suppressed until it is needed for use on the drawing or in the construction of a feature in sheet metal mode.
To create the geometry of your forms (dimples) surface geometry will regenerate in the least amount of time. When creating a solid version, the use of the geometry pattern function can be used to array the surfaces and solidify them. There is also the option in sheet metal mode to use the quilt form and reference a quilt created in an external model that is optimized for a fast regen time. This reference feature (i.e. external copy geometry) can be set to read only so that it never regenerates which may reduce regen in some cases.
