Dale_Rosema
Limits Dimension (Side by side vs Above/Below)
  • September 8, 2020
  • 4 replies
  • 6413 views
What config in the drawing config file controls whether a "Limits" dimension is Lower-Higher (side by side) vs Higher/Lower (above and below)?
Best answer by Dale_Rosema
ProWorkAround:
Making sure that the default_tolerance_display_style: std_asme
A new dimension was created and now its hyphenated.
Then delete  erase old dimension (in case the stacked version is used in another instance and will disappear from those instances).
Looks like this:
Oddly enough, it doesn't seem to be doing anything in my test drawing.  Hmmm.  (Creo Parametric 6.0.5.0)
Dale_Rosema
Both drawings had default_tolerance_display_style: std_asme
Dale_Rosema
Server reboot causing other issues. I'll have to get back to this later.
It looks like this option might be the one you want to mess around with. I did a quick test and it looks like the orientation of the dimension matters. This seems a little odd and definitely inconvenient. There's also separate settings for the other types of dimensions.
Ty
Dale_Rosema
Both of my drawings have default_lindim_text_orientation: horizontal
Dale_Rosema
Doesn't this config have to do with the text being inline with, above or below the leader?
Dale_Rosema
Dale_Rosema23-Emerald IIIAuthorAnswer
ProWorkAround:
