Limits Dimension (Side by side vs Above/Below)
What config in the drawing config file controls whether a "Limits" dimension is Lower-Higher (side by side) vs Higher/Lower (above and below)?
ProWorkAround:
Making sure that the default_tolerance_display_style: std_asme
A new dimension was created and now its hyphenated.
Then delete erase old dimension (in case the stacked version is used in another instance and will disappear from those instances).
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
