Logo engraved on parts
After years of using ProE with most of the functionalities I found that placing a logo on parts become very difficult.
I have a logo (DXF, IGS or DRW format)
I need to place this one in 3D model and the 3D model will be used to be manufactured.
Witch one is the easiest way.
The logo contains several hundred of entities.
If I use a symbol this one is not recognized in 3D model
if I use curve or costetic the sketch will die trying to regenerate hundred of lines
if I import the IGS becomes a problem if I want to change the scale of the logo based on part size
is it there any way to place a logo in 1 min.
Thx,
CC
