Looking for a specific type of Rotational Equation Curve
I have successfully used a specifically sized flat Equation curve in my die designs. I have on a number of occasions however needed to use the same radius and spacing around a rotation which to this point have been very fudgy.
Below is the equation that I have been using.
This results in a curve like the following.
Would it be possible to make an equation curve to the below shape?
The spacing would be the same as with the top example but I would somehow need to be able to define a center or slope. Can this be done?
