Managing windows in a session by VBA from excel
  • November 21, 2016
  • 2824 views
I am new in VBA API and so to related it'e objects.
As final result I need to run some mapkey macro in a Model by starting the Macro in an OLE excel fiel inside a Drawing.
For now I need to manage the asynchronous session window as first step.
Solved this problem I need to manage the relation and write some parameters.
So passing directly to the first step, this is my Code to start the asyncConnection (Is there some unnecessary code be patient) :
The first problem is in BOLD.
Public Sub Macro1()
    Dim asyncConnection As New pfcls.CCpfcAsyncConnection
    Dim cAC As pfcls.IpfcAsyncConnection
    Dim session As pfcls.IpfcBaseSession
    'Dim descModel As IpfcModelDescriptor
    'Dim descModelCreate As CCpfcModelDescriptor
    'Dim model As IpfcModel
    Dim workDir As String
    Dim position As Integer
    'Dim Appli As String
    Dim mdlname
    Dim drwname
    Dim a
    On Error GoTo RunError
    'Get asyncConnection
    Set cAC = asyncConnection.Connect(dbnull, dbnull, dbnull, dbnull)
    Set session = cAC.session
    'Get current directory
    'Set it as working directory
    workDir = ActiveWorkbook.FullName
    position = InStrRev(workDir, "\")
    workDir = Left(workDir, position)
    session.ChangeDirectory (workDir)
    drwname = session.CurrentModel.Filename
    MsgBox ("Name: " & drwname)
    'Mapkey to focus on model of the drawing
session.RunMacro ("mapkey $F9 ~ FocusIn `main_dlg_cur` `proe_win`;" + "mapkey(continued) ~ Select `main_dlg_cur` `PHTLeft.AssyTree` 1 `node0`;" + "mapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `PREVIEW_POPUP_TIMER`" _
+ "mapkey(continued) `main_dlg_w1:PHTLeft.AssyTree:<NULL>`;" + "mapkey(continued) ~ RButtonArm `main_dlg_cur` `PHTLeft.AssyTree` `node0`;" + "mapkey(continued) ~ PopupOver `main_dlg_cur` `ActionMenu` 1 `PHTLeft.AssyTree`;" _
+ "mapkey(continued) ~ Open `main_dlg_cur` `ActionMenu`;~ Close `main_dlg_cur` `ActionMenu`;" + "mapkey(continued) ~ Activate `main_dlg_cur` `OpenModel`;" + "mapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `PREVIEW_POPUP_TIMER` " _
+ "mapkey(continued) `main_dlg_w2:PHTLeft.AssyTree:<NULL>`;~ Command `ProCmdEnvShadedEdges`  1;")
mdlname = session.CurrentModel.Filename
MsgBox ("Name: " & mdlname)
    session.RunMacro ("mapkey $F8 @MAPKEY_LABELOFF_H;~ FocusIn `main_dlg_cur` `proe_win`;" + "mapkey(continued) ~ Command `ProCmdDToolsOptim` ;~ Activate `optimization` `OpenStudyTB`;" + "mapkey(continued) ~ Select `seldstudy` `DesignStudyList` 1 `OPTI_OFF_H_1`;" + "mapkey(continued) ~ Activate `seldstudy` `OKButton`;~ Open `optimization` `GoalParameters`;" _
+ "mapkey(continued) ~ Close `optimization` `GoalParameters`;" _
+ "mapkey(continued) ~ Select `optimization` `GoalParameters` 1 `PROJ_DISTANCE:43379`;" _
+ "mapkey(continued) @MANUAL_PAUSENow you mast imput the desidered OFF_H value;" + "mapkey(continued) ~ Arm `optimization` `ConstrTable` 2 `PROJ_DISTANCE:43379 (12)` `Value`;" _
+ "mapkey(continued) ~ Select `optimization` `ConstrTable` 2 `PROJ_DISTANCE:43379 (12)` `Value`;" + "mapkey(continued) @MANUAL_PAUSEOFF_H_1 ?;" _
+ "mapkey(continued) ~ Arm `optimization` `ConstrTable` 2 `PROJ_DISTANCE:43380 (13)` `Value`;" + "mapkey(continued) ~ Select `optimization` `ConstrTable` 2 `PROJ_DISTANCE:43380 (13)` `Value`;" _
+ "mapkey(continued) @MANUAL_PAUSEOFF_H2;" + "mapkey(continued) ~ Arm `optimization` `ConstrTable` 2 `PROJ_DISTANCE:43381 (14)` `Value`;" _
+ "mapkey(continued) ~ Select `optimization` `ConstrTable` 2 `PROJ_DISTANCE:43381 (14)` `Value`;" + "mapkey(continued) @MANUAL_PAUSEOFF_H_3;" _
+ "mapkey(continued) ~ Arm `optimization` `ConstrTable` 2 `PROJ_DISTANCE:43382 (15)` `Value`;" _
+ "mapkey(continued) ~ Select `optimization` `ConstrTable` 2 `PROJ_DISTANCE:43382 (15)` `Value`;" _
+ "mapkey(continued) @MANUAL_PAUSEOFF_H_4;" + "mapkey(continued) ~ Arm `optimization` `ConstrTable` 2 `PROJ_DISTANCE:43383 (16)` `Value`;" + "mapkey(continued) ~ Select `optimization` `ConstrTable` 2 `PROJ_DISTANCE:43383 (16)` `Value`;" + "mapkey(continued) @MANUAL_PAUSEOFF_H_5;" + "mapkey(continued) ~ Arm `optimization` `ConstrTable` 2 `PROJ_DISTANCE:43384 (17)` `Value`;" + "mapkey(continued) ~ Select `optimization` `ConstrTable` 2 `PROJ_DISTANCE:43384 (17)` `Value`;" + "mapkey(continued) @MANUAL_PAUSEOFF_H_6;" + "mapkey(continued) @MANUAL_PAUSENow the calculation is starting, it take about 15 seconds, be " + "mapkey(continued) patient.;~ Activate `optimization` `ComputeTB`;" + "mapkey(continued) ~ Open `optimization` `GoalParameters`;" + "mapkey(continued) ~ Close `optimization` `GoalParameters`;" + "mapkey(continued) ~ Select `optimization` `GoalParameters` 1 `PROJ_DISTANCE:43380`;" _
+ "mapkey(continued) ~ Activate `optimization` `ComputeTB`;~ Open `optimization` `GoalParameters`;" _
+ "mapkey(continued) ~ Select `optimization` `GoalParameters` 1 `PROJ_DISTANCE:43381`;" _
+ "mapkey(continued) ~ Select `optimization` `GoalParameters` 1 `PROJ_DISTANCE:43382`;" _
+ "mapkey(continued) ~ Select `optimization` `GoalParameters` 1 `PROJ_DISTANCE:43383`;" _
+ "mapkey(continued) ~ Select `optimization` `GoalParameters` 1 `PROJ_DISTANCE:43384`;" _
+ "mapkey(continued) ~ Activate `optimization` `ComputeTB`;~ Close `graph_wnd` `graph_wnd`;" _
+ "mapkey(continued) ~ Activate `optimization` `CloseButton`;~ Activate `ds_exit` `OKButton`;")
'Now I should go back to drawing and disconnect but I am unable to manage in any way the Focus/Activation of any session window.
a = session.ListWindows()
    MsgBox ("Name: " & a)
'End the Creo Parametric session when done
RunError:
If Err.Number <> 0 Then
  MsgBox "Process Failed : Unknown error occurred." + Chr(13) + _
            "Error No: " + CStr(Err.Number) + Chr(13) + _
            "Error: " + Err.Description, vbCritical, "Error"
    If Not conn Is Nothing Then
        If conn.IsRunning Then
            conn.Disconnect (2)
       End If
    End If
End If
End Sub
I am not sure if I understand what is the problem? Do you want to display a message in Creo? Or do you want just to show the message box?
No, I put a message box only to check the value stored in the "session.ListWindows()" because during the debug working from vba (Excel editor) the editor do not show anythings if the value is not stered in a Variable, so before to start managing the windows object I wont se if a reach something.
You can try this!!
Windows = BSession.ListWindows()
        For Each Window In Windows
            ModelName = ModelName + Window.Model.FullName + vbCrLf
        Next
MessageBox.Show(ModelName)
