Measure distance in X Y Z direction is not working
  • June 6, 2018
  • 11197 views
I tried to measure the distance between 2 points in x y z direction ,
I think i have used the right option, but the option seems to be not working (please see attached image)
any suggestions.
Thanks in advance.
Best answer by Ian_Cure
See attached, firstly "click here to add item" button and then select If you're in a part use the parts csys (pick in model tree) If you're in an assembly then pick the top assembly csys
use a csys in the projection box and expand the results window
vdevan1-VisitorAuthor
hey lan,
Thanks for your  reply.
i tried again, But , that csys option is not showing for me ..
please take a look at the previous image i shared....
Ian_Cure13-AquamarineAnswer
