Merge/Inheritance Feature - Manual Update - Yellow Triangle - Why?
CREO 5
I have a part with a merge/inheritance feature as the first feature, which references a different part, but this feature is set to 'Manual Update'. Why then is there a yellow triangle in my model tree indicating that the referenced part is not in session? Manual Update should imply that the link is broken, right? Hence, the option to select 'Automatic Update', which would continuously search for the referenced part? If I select 'No Dependency' will the link be broken with the referenced part for good, or can it be re-established?
