ModelCHECK SIMPREP_NAME
  • August 18, 2014
  • 2116 views
Has anyone set this up before. I set it up in the check files as an error, but can not figure out how to get this added to the start files. Any suggestions? The help docs are not very clear on this topic.
Best answer by Mahesh_Sharma
You can directly add this information in start file using text editor.
From Environment tool set:
Select type of start item as Simprep
Enter the name
Skip the Value
22-Sapphire I
September 2, 2014
Scottb,
Will you explain your requirement in detail about this?
We have 2 default simprep names, I would like to validate that those are in the models. Then they can have others if they wish.
22-Sapphire I
September 3, 2014
Try adding the below parametrs in start file (*.mcs):
For Assembly:
ASM_SIMPREP Name_of_Ist_Simp_Rep
ASM_SIMPREP Name_of_IInd_Simp_Rep
For part:
PRT_SIMPREP Name_of_Ist_Simp_Rep
PRT_SIMPREP Name_of_IInd_Simp_Rep
