7-Bedrock
October 5, 2022
ModelCHECK not working on harness MFG
  • October 5, 2022
  • 2 replies
  • 1798 views
I have been trying to run MODELcheck in created MFG assembly (nailboard), but the button is grayed out and I'm not possible to use it. I tried to edit my config_init, but I'm not sure what exactly should I look for.
1. What version of the program are you using?
2. Please show a screenshot of your issue.
7-Bedrock
October 6, 2022
I am using Creo 7.0.
This is the issue. without modelcheck I cannot checkin the assembly. So I guess there has to be a way how to enable it.
I am not sure whether MODELcheck can check MFG assembly. I guess that that in checks parts, assemblies and drawings, only.
7-Bedrock
October 6, 2022
Thanks for your reply. Without modelcheck process, I'm unable to CheckIn the assembly to commonspace. If I try to CheckIn the assembly without modelcheck, conflict managment window will pop up with error.
if you have active Support at PTC then I suggest you to contact PTC Support.
