ModelCHECK_parameters in Cyrillic
  • November 15, 2019
  • 2 replies
  • 2054 views
Hello everyone!
ModelCHECK does not accept model parameters in Cyrillic.
How can I fix this problem?
Regards!
Best answer by VladiSlav
Hello!
I found a solution:
It is necessary to select the parameter MC_SUPPORT_LEGACY_STRING in the config_init.mc file (select "N").
Then reload Creo Parametric.
Then everything worked in my case.
Best Regards!
Mahesh_Sharma
22-Sapphire I
November 15, 2019
@VladiSlav
Can you share a text file with such words? Also, it will be worth looking at post https://community.ptc.com/t5/System-Administration/Work-with-existing-vowel-mutation-%C3%A4-%C3%B6-%C3%BC-%C3%84-%C3%96-%C3%9C/m-p/605956
my suggestion ... report the problem to PTC Support.
VladiSlav17-PeridotAuthorAnswer
Hello!
I found a solution:
Best Regards!
