7-Bedrock
June 18, 2024
Open file of other cad system
  • June 18, 2024
  • 1431 views
Hello
when open one file of other cad system (like Cathia, SolidWork, ecc) Creo Parametric create a new file with extension (.creo) in the same folder of the original file.
I'd like to controll the option to create or not create, and the position of cration.
Dale_Rosema
When you say the position of creation, do you mean file folder, the coordinate system of the created part, or something else?
ecrespi7-BedrockAuthor
7-Bedrock
June 18, 2024
Hello
i mean the file folder. For the moment CreoParametric create the file in the same folder of the original file.
What is your working directory set to? Are you opening the other file from the working directory and Creo is placing the creo file in the same folder?
Try setting the working directory to another folder where you want the creo file and then browser to the location of the other cad file and open it. See if that gives you what you want.
