Opening a table pattern in excel with excel open
  • April 25, 2022
  • 2 replies
  • 4389 views
First, the parameter part_table_editor is set to "excel"
That said, Creo will not allow me to open and edit a table pattern in excel if I already have another excel window open.
When attempting to do that it throws this error:
The fix I have found (which is incredibly inefficient) is to close all open excel windows, open the table pattern, then reopen the excel files I am using to generate the data needed for the table pattern.
Does anyone know if there is a fix that will allow me to open table patterns in excel without closing all other excel windows?
    Here you are in the Creo Elements direct / Modeling community.
    You should better move your post to the Creo Parametric to have a better chance to get an answer.
    Ah thanks - my mistake.
    22-Sapphire I
    April 26, 2022
    Hi @BrianBoman
    Article CS206558 may help.
    Hello @Mahesh_Sharma ,
    I was able to have our admins comment out the browser setting in the config.sup to do some initial testing. Interestingly enough both options (ie_in_sep_process and mozilla_based_browser) no longer seem to be recognized as valid settings. I checked both of them and they were both flagged (as seen in the pictures) as invalid options. I looked in the config options under the embedded help and they are not mentioned there. I also checked proesite.com/windows_browser_type and found the same. My working directory does not seem to be changing once I launch Creo either. That said, I did try setting it to be my desktop over my working folder but it didn't fix the issue. Any additional thoughts?
    That article is definitely wrong.  Those values do not exist in Creo 6.
