Opening a table pattern in excel with excel open
  • April 25, 2022
  • 2 replies
  • 4389 views
First, the parameter part_table_editor is set to "excel"
That said, Creo will not allow me to open and edit a table pattern in excel if I already have another excel window open.
When attempting to do that it throws this error:
The fix I have found (which is incredibly inefficient) is to close all open excel windows, open the table pattern, then reopen the excel files I am using to generate the data needed for the table pattern.
Does anyone know if there is a fix that will allow me to open table patterns in excel without closing all other excel windows?
    Here you are in the Creo Elements direct / Modeling community.
    You should better move your post to the Creo Parametric to have a better chance to get an answer.
    Ah thanks - my mistake.
    22-Sapphire I
    April 26, 2022
    Hi @BrianBoman
    Article CS206558 may help.
    Hello @Mahesh_Sharma ,
    I was able to have our admins comment out the browser setting in the config.sup to do some initial testing. Interestingly enough both options (ie_in_sep_process and mozilla_based_browser) no longer seem to be recognized as valid settings. I checked both of them and they were both flagged (as seen in the pictures) as invalid options. I looked in the config options under the embedded help and they are not mentioned there. I also checked proesite.com/windows_browser_type and found the same. My working directory does not seem to be changing once I launch Creo either. That said, I did try setting it to be my desktop over my working folder but it didn't fix the issue. Any additional thoughts?
    22-Sapphire I
    May 4, 2022
    Hi @awei3
    I think this issue may need some investigation on user machine. Possibly a  case with TS may help.
    Thanks.
