Overlapping Parts in Assembly
I have an assembly with overlapping parts and I'm trying to remove the overlapping material from one of the parts only. After doing some search most answers were as follows:
"In your assem activate your main part. copy all the surfaces of the secondary part. use solidify to cut the quilt from the main part. Also, have you tried to merge the parts in your assem? (edit>component operations>merge)"
I'm not sure what that means exactly but these are the steps which I have done.
- Component Operations > Copy.
When doing this I cannot select the part which needs to stay in its original state.
I tried something else which is:
- Components Operations > Boolean Operations > Cut
Still I cannot select the part which needs to stay in its original state.
Does anyone know the reason for this problem? Can anyone suggest any other solutions please.
