PKG IMPORT FROM BATC x CREO 8
  • December 12, 2024
  • 694 views
Hi I would like to understand if it is possible to program a .ttd file for Creo Distributed Batch,
to import and convert pkg files I am using creo parametric 8
If it is not possible I ask to program a Mapkeys in Creo Distributed Batch, for that activity.
If I use creo with normal operations I can convert the file but I need to program the conversion activity without engaging the program as for the steps.
I am trying to reprogram a ttd file from another but it fails I am missing some information. I was looking for a guide.
THIS IS THE TEST I DID .. ON TTD FILES but obviously it fails
Translated by the moderation using Google Translate
Ciao vorrei capire se è possibile programmare un file .ttd per Creo Distributed Batch,
per importare e convertire file pkg sto usando creo parametric 8
Se non fosse possibile chiedo per programmare una Mapkeys in Creo Distributed Batch, per quella attività.
Se uso creo con operazioni normale riesco a convertire il file ma ho necessità di programmare l'attività di conversione senza impegnare il programma come per gli step.
sto tentando di riprogrammare un file ttd da un'altro ma fallisce mi mancano delle informazioni. Cercavo una guida.
QUESTO IL TEST CHE HO FATTO .. SU FILE TTD ma ovviamente fallisce
<?xml version="1.0" encoding="UTF-8"?>
<!-- 18-Feb-02 J-03-19 TWH  $$1  Submitted -->
<!-- 12-Aug-02 J-03-31 TWH  $$2  Drop create_type node -->
<!-- 16-Aug-02 J-03-32 MFL  $$3  Added node <DETAILS> -->
<!-- 30-Aug-02 J-03-33 MFL  $$4  Added create_type node, since automatic create type detection is not supported.
   Also, added updated the TTD description and details to reflect parts. -->
<!-- 20-Aug-03 K-01-13 TWH  $$5  Adjust DETAILS node -->
<!-- 17-Sep-08 L-03-19 TWH  $$6  Chg function to use profile -->
<!-- 14-Jan-11 L-05-40 TWH  $$7  Rebrading -->
<!-- 11-Aug-14 P-20-59 mtch $$8  Use ProIntfimportModelWithOptionsMdlnameCreate -->
<!-- 17-Feb-15 P-30-03 mtch $$9  Added group -->
<!-- 03-Sep-15 P-30-16 mtch $$10 Added FILTER_FILE_TYPES -->
<TTD version="1.0" created_by="PTC">
<DESCRIPTION>PKG 3D Import </DESCRIPTION>
    <GROUP>PKG</GROUP>
<DETAILS>Import PKG 3D (.pkg) files to create Creo Pro Parts (.prt) and Assemblies (.asm)</DETAILS>
<SERVICE name="dbatchs"/>
<FILTER_FILE_TYPES type=".pkg"/>
<TKFUNC func="ProIntfimportModelWithOptionsMdlnameCreate" profile_type="dip">
<type enum="PRO_INTF_IMPORT_CC"/>
</TKFUNC>
</TTD>
Grazie
1.]
Suggestion: Please ask PTC Support whether it is possible to create requested TTD file.
2.]
Solution: Generate trail file executing .pkg import -AND- save as Creo model. Then play this trail file from Creo session.
I'm with Martin on this one, using Option 2. If it can be done with normal Creo operations and is a repeatable process, a trail file is a nice way to do these kinds of things.
