Parameters on Drawings
I currently have a drawing template set up to use multiple drawing parameters (for example, item description, file name, revision, etc). When I create a new drawing using this template, before letting me view the drawing, it pops up a dialogue box for each use of the parameter. So, for example, it the revision parameter is used twice on the drawing template, there will be two different dialogue boxes which pop up which each ask you to input the revisions.
I would much rather either input the value into one dialogue box (again, it's the SAME parameter) or be able to open the drawing and then fill in all my parameter values at once (through the parameter option under tools? unless there is a better location?)
Is there a way to change this?
