Pi Symbol in a note in WF5
  • January 30, 2013
  • 3 replies
  • 2081 views
Is there a way to put the Pi symbol in a note in WF5
There is not one in the symbol pallet.
    There may be one in the font you are using under special characters.
    Thank you,
    Ben H. Loosli
    USEC, INC.
    π . Alternately you can use the ASCII alt-227 code(hold down the "ALT" key and type 227) in notepad (or copy the pi from this email) and paste it into the text editor. It doesn't seem to work with the standard PTC "font" but it should work if you are using a Windows font. I use these two site for my references.
    WF5 comes with a Greek font which has pi on the letter p. You can change text style to Greek for a that part of you note by surrounding it like {p}
    /Bjarne
