Pictures in parts and drawings
- April 23, 2024
- 1 reply
- 2441 views
I'm using Creo Parametric Release 7.0 and Datecode 7.0.9.0
Hello
I inserted an image into a part and then integrated that part into the assembly. Now I would like to install the same part into the assembly again. Now the following happens, it no longer shows me the image, even though it is present in the part. The image still displays with the first part installed, but no longer with the second. The images cannot be seen in the drawing at all, why is that? Can you change that?
Thanks and best regards
