Problem : Delete segment with Modernized project/offset tool
Hello
I'm creating this post following the switch from CREO 8 to CREO 10.
I make a lot of use of the offset/projection and segment uncut functions in the sketches I create, except that with the new tool this is totally broken.
Here's an image to illustrate my problem : I want to remove the corner and keep the two straight lines.
I was able to browse other topics where the subject of the new tool is discussed but no solution seems to have been given.
Do you have any information on the subject? Would it be possible to have an option to go back to the old tool or to make it differently ? Is it possible to no longer consider the projection/offset as a loop?
Thanks and have a nice day,
Leo
