Problem in importing an excel file into Creo drawing
ftorabi
Hi All
I was trying to import an excel table, save in CSV_(MS DOS) format into my Creo 2 drawing sheet. The reason was that it's too hard to modify a designed table in the Creo drawing sheets.
The error was that some columns have more rows that the other ones. Which is not true.
In my file there are two columns, one with letters and the other with numbers, and there is no empty row. So I have no idea why it doesn't accept my excel file import.
My idea was to always modify  the tables on the excel and re-import them to my Creo drawing
Hi ftorabi
Perhaps you already solved this - but here's the solution:
Creo will only accept if the CSV-file contains "," [comma] for column shifts - and "." [period] as decimal-limiter.
I hope it helps
greetings
Anders
