Problems in the area graphically.
  • January 14, 2013
  • 2 replies
  • 1649 views
Hello I wonder if anyone ever had this kind of problem with the graphical area because when I open a project or design whatever he always does in the area grafica extremities. image following to facilitate understanding the problem.
Now that would be annoying!
Try changing the graphics to something other than "opengl" in config.pro.
Most people recommended is win32_gdi. "graphics win32_gdi".
This is most often blamed on graphics drivers or accelerators. You can play with the graphics card settings also. Creo/WF/Pro/E have always been sensitive to graphics drivers and hardware.
If nothing works, contact customer support. Actually, it is always good to log a case so they can have a look at it.
André,
I have seen the same efect, when I installed Creo 1.0 on my old PC a long time ago. Because my PC contained old graphic card (its manufacturer did not update drivers), I had to replace old graphic card with new one.
Try to find and install up-to-date graphic card drivers for your current graphic card. If they do not exist, you have to buy new graphic card.
Martin Hanak
Thanks guys, it worked only in exchange for confg.pro win32_gdi, I am grateful for that.
One more question in creo when you hover the mouse on the piece she makes a selection in green have to disable it in confg.pro too?
grateful ......
Happy this worked, André.
There are two colors green. High light (light green), and what you are seeing, pre-high light (darker green). This is normal behavior. If you change the filter at the bottom-right of the screen to a different type of feature, it will not pre-high light the geometry. This action is very dependent on your currently active ribbon command also.
