Hello @ptc-222825
If it's what I have in mind, it is a known issue to us impacting the specific Creo Parametric 7.0.5.0 datecode.
We document this in our article 352370.
Hope this helps,
Serge
Read the following article - "Error message generated in the datafile.ers in Creo Elements/Pro 5.0 and Creo Parametric": https://www.ptc.com/en/support/article/CS53504
please upload datafile.ers file. It is usually located in startup directory.
This is part of my problem. I cannot find the datafile.ers anywhere. I have checked the start in location and the PTC program files. Is there a way to figure out where this file is located? Or, is there something that would prevent this .ers file from being created by Creo?
Try uploading your prodetail.dtl here in the forum and maybe we can look at it to see if there is something wrong?
Is it only for one part/model or one drawing or for everything you create? If it is for everything, make a test model / drawing and upload that so someone on here can look at it.
Another option is to open support case with PTC esupport. Based on your post, I suspect that is where you went and it suggested posting to the community, you can ignore that suggestion and open a support case. They will likely want a model/drawing also.
I have attached my config file and drawing config .dtl file. I only have this issue with a couple parts, and I can't find a difference in parts that it happens to vs. the other parts.
Hello @ptc-222825
Hope this helps,
Serge
Thanks for the tip Serge. This does seem to be an acceptable solution
