Program function IF ?
  • January 9, 2023
  • 1975 views
Hello everyone,
I would like to know if there is a function IF or one who look a like in CREO.
I cant find one on the Forum or on CREO.
An by the way, what is the language in CREO.
I work on creo since a couple of months so i'm not really use to it.
I hope someone will read it .
Thank youu for reading !
Best answer by TomU
Creo Parametric's built-in programming support (Relation Pro/Program, Drawing Program, etc.) uses it's own internal language.  There is no looping allowed, so no WHILE, GOTO, or anything like that.  You can read more about it here:
https://support.ptc.com/help/creo/creo_pma/r9.0/usascii/#page/fundamentals/fundamentals/About_Relations_1.html#
You will probably get a better answer if you explain what you are trying to do instead of asking for a specific function.
There are multiple areas you can add functions. Pro/Program, relations, repeat region relations.
Yes,
my bad.
I write IF but I mean WHILE
TomU23-Emerald IVAnswer
