Reattaching a GTOL / GTOL lost it's reference arrow..
Hi guys,
Another #$%^& with Creo: GTOL placements.
I have a dwg, and I had a GTOL attached to a surface with an arrow (someone else did this, so I don't know exactly what was done.) I’ve since made a change to the part (Revised a radius), and surprise! Creo has lost its reference to what it was attached to*. So, now I have a GTOL floating around on a dwg, and I cannot for the life of me, figure out how to bring the arrow back / reattach it...
This shouldn’t be a time consuming, convoluted thing to do.. (but, sigh, this is Creo..)
I can get eh GTOL refence dialog up, but it' says everything is complete. Yet eth GTOL box is just floating around. No leader / arrow.. and when I try to "reattachment" it comes up with a warning that doing so will break any association with the original placement..
Doubly frustrating is how you can't 'escape' out of a command. in this case, I've been trying different things to get it to 'reattach', but when I try to 'Select' Entity' it hangs, as I can't seem to pick the entity I want.. (So I have to select another function, to force it to 'cancel & close'..
* I’m constantly amazed at how easily Creo loses references when an apparently unrelated change is made..
