Is there keystroke I am missing that will remove these objects? CTRL + R removes the entire chain set. The only option I see if right click and click remove for everyone of them. I tried to build a mapkey but it referenced the line item and that hindered the ability to flex it across the entire list. This reference collector is used all over the core package. There must be a better way than to right click and then click remove.....everytime.
Any ideas?
I found a better way to do this
Open the find and select binoculars and use that list to batch select them since that is possible on that tool.
Open binocs
Click hold shift click
Right click and remove in bulk
Open binocs
