Repeat Region Sort
- February 7, 2023
- 3 replies
- 2804 views
So I think you found my issue. I recently changed my start part to have the Purchased and Fabricated parameters as restricted. In doing so it is putting a "space" in the parameter if I don't select anything. To test this, I put a space in an older part and it moved up in the BOM to where it should be.
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
