Repeated reference pattern issue
  • April 11, 2022
  • 3125 views
I'm having an issue with performing repeated patterns on a quilt.  Unfortunately I can't share much due to confidentiality so will have to do my best to describe.
I'm starting with a 'base/origin' quilt on which I perform a number of patterned merges.  Usually I model another quilt which is to be merged, copy that quilt, pattern the copy, merge the first copy with the base quilt (ensuring the base quilt is selected first), select that merge feature and select pattern which would automatically detect the previous pattern and do a reference pattern of the merge.
However on this particular model this works once but when I try and do it a second time, the pattern feature button is either greyed out or the pattern instances are overlaid in a single point (seems to vary when I've fiddled around to get around the problem). If I create a copy of the base/original quilt and merge with this instead, the second reference pattern works fine (as do subsequent patterns but a copy of the base/original quilt is required each time) but there are fairly major disadvantages to not being able to carry a single quilt/feature reference through the design process.
From what I've managed to find by googling there seems to historically have been some issues/bugs with reference patterning. My general understanding is Creo sometimes struggles with which previous pattern to reference if there are multiples.
Is anyone able to clarify this for me? Is there a reliable way of making it clear/isolating which pattern is to be referenced? Any help would be greatly appreciated.
tbraxton
While your verbal description is readable, it is difficult to root cause the problem without a sample data set for evaluation. Can you create a simplified set of model(s) that demonstrate the problem and post them?
Are geometry patterns possibly the right tool to implement what you are trying to do? That is something to explore. The other issue that may be relevant here is that when you merge quilts the internal feature IDs may be getting updated and that can cause reference problems. Does your base quilt have multiple patches within it? You should be able to use the global reference viewer to gain insight into the references before and after your attempt to pattern to see what is happening.
The attached is analogous to my part.  For some reason I can't do a reference pattern on the last merge feature (F24).  Nothing terribly complicated.  Can't understand why.  Thanks for your help.
Really appreciate you looking into this for me.  Unfortunately I'm only running Creo 4.0 so can't open the file you shared (even with GCRI) - shame as would have been interested to look at it.
I'll have a read up about the circle splitting thing and see if that explains the issue.
