Retrieve PTC Common name without full assembly in session?
I'm using Creo 7 and Windchill 12.
My model tree setup has got a column in for PTC_COMMON_NAME, which we use as the human-readable descriptor of the cad part/assembly.
Some of the sub-assemblies are quite heavy so I don't want to have to retrieve them and bring them into session only to find out that's not the section I was looking for; i.e. I can't remember if the part I want to see is in 100_8 or 100_9, but if the common names were shown I would be able to tell which one I need.
When I open this top level master scheme the common name column is all blank, and when I set the sub-assembly to a master rep it retrieves the common name and displays it, but I'd much prefer to make it retrieve the common names of each of the assemblies within the top level, without bringing their assembly contents into session; is that possible?
I think I can make a user defined "empty" rep in every individual sub-assy and then re-define the master scheme "empty" rep to call up each of those user defined reps rather than an exclude, but that would necessitate defining those reps one by one and checking the whole lot in again.
