Save a Copy of an Assembly with Drawings
  • March 7, 2025
  • 1089 views
Hi Folks,
Using CREO 7.0.8.0
I have never been able to understand what the purpose of the radio button designated 'Copy Drawings' is for. I always have it selected when copying an assembly in the graphics window, but drawings are never copied, neither for the renamed assembly nor any of the renamed sub components. What is the purpose of this selection? Thank you.
If the associated drawing is in session, it will also be "Saved As" to the same directory.  Works in 8.0.
wbottis14-AlexandriteAuthor
I just gave it a shot. I opened the top assembly and the drawing as well as a sub-assembly and its drawing, then saved the top-assembly with 'Copy Drawings' checked. Not even the top assembly drawing with the new name was created.
I believe for this check-box to work, the components / assemblies being saved-as have to have the same name as their drawings.
Then the system will create copies of their drawings with the new names as well.
See this thread: Copy drawing and model and attach them , for example.
