Save assembly Representation as separate assembly
  • July 18, 2024
  • 2 replies
  • 1445 views
I have an assembly that has multiple representations , am using Creo 8 and no windchill.
I want to save one representation as standalone assembly without referencing main assembly. Below is the workflow I have tried:
When I use above method , I get new assembly as per below image. I did not select dependent checkbox
My question is:
1. why does my new assembly has different icon?
2. Why does new assembly still being linked with main assembly (see below image)
Best answer by Lewis_Maina_M
I did research on this topic , an this is the findings:
Its possible to save a representation as a stand alone assembly but its still a representation rather than a real assembly hence cannot be assembled in other assembly and it still has reference connection with the original assembly. See  below image
Marking this question as resolved
My new assembly ASM0003 is now parent to initial assembly ASM001. I would like to understand what's going on.
Lewis_Maina_M13-AquamarineAuthorAnswer
