Scale when importing a DXF
- May 10, 2012
- 4 replies
- 14755 views
ia am using Creo Elements/Direct Modeling Express 4.
I want to create a 3D Body out of an imported DXF drawing.
I have drawn the DXF in scale 25.40 but before exporting to DXF I changed to 1:1.
If I measure DXF in my 2D CAD I get 84mm.
But when i import it the scale is wrong. I get 2133,6mm instead of 84mm (a factor of 25.4).
The 3D Body has correct length (84mm) after editing scale to 25.4.
In Annotation the length is wrong with 2133,6mm!
When I enter this factor to the units under system settings, i can measure the correct values.
But when i do a STL export then I get a body without this factor.
Is it possible to enter a "hard" factor while importing a DXF, that the base data is correct
and the system does not referr to the wrong imperial dxf data.
