Setting up Modelcheck
At the company i work for we're using Creo Parametric 3.0 M030. Last half year we've been busy setting up Creo and at the moment i'm looking into Creo Modelcheck. So far it's not clear what is possible and how it has to be done. Therefor some information and expertise on using Modelcheck is welcome. Below are a few things i hope to achieve by using Modelcheck, if it is possible:
- Check if units are set to mmKs, if not change it to mmKs;
- Remove unwanted parameters: "Parameter_1", "Parameter_2" etc.;
- Add parameters defined in the assembly and part templates, if not already present in the part.
Thanks!
Dave
