Sheet metal import step file with variable thickness
Hello!
I want to import a press-fit pin tip with variable thickness (stp file). It can be imported only as a sheel, and if I want to generate a stp file afterwards, it won't show the pin tip anymore.
It is a way to solve this problem?
