Show DFS in Drawing for Merge/Inheritance Feature in Creo4
In older versions of Creo, i.e. Creo2, you could show Datum Tags from the base model that was used in a Merge/Inheritance feature. In Creo4 they will not show up. This is how we typically create our sand casting drawings. The sand cast core model will have a Datum Feature Symbol (Datum Tag) on a bore, for example, and we want to show that datum in the drawing.
Can anyone help with this? TIA.
