Solidify Quilt
  • August 6, 2020
  • 6781 views
I would like a SOLID model of attached IGES. It comes in as a quilt.
Need to apply a weight.
Can someone tell me how to do this?
Or if you can do it simply enough that would be awesome.
I am helping a colleague.
Need in CREO 6.0. Or perhaps redone as an import in solid form.
Much Thanks!
WayneF
Best answer by Tdaugherty
Here is a model that has been fixed and solidified. I've attached a STEP file.
To fix the quilt, I used the repair tool in data doctor. This method doesn't always work but for messed up threads, it's usually the first thing I try. Another way to fix this would have been to remove the threads altogether or patch the quilt manually.
Ty
Ty
wfalco16-PearlAuthor
Td
I owe you my brother!
I am going to send what you sent me to my colleague. I tried, it worked. Cool Beans! 1000 thanks!
I will also try the Data Doctor. I should really spend more time with that than I have.
Have a great day!
Wayne
