Spline in Parametric 3.0
  • November 8, 2017
  • 2763 views
I'm working on some project and I'm using CREO parametric 3.0. I'm having a problem to identify the spline method implemented in Parametric 3.0. Which type of spline equation used in CREO? Is it NURBS or B-Spline curved equation or other type of spline curves?. Does anyone know or perhaps give me the link to answer this question?
thank you in advance.
regards.
22-Sapphire I
November 8, 2017
You can check by removing creo_parametric_customization.ui
By default it wikll be under <User>\AppData\Roaming\PTC\ProENGINEER\Wildfire\.wf
CarraM291-VisitorAuthor
Thanks for some reason it has appeared back!
22-Sapphire I
November 8, 2017
You may close the post by accepting your comments as solution.
